Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 01-06-2006, 03:21 PM
LittleTruck LittleTruck is offline
32 Ford Model B
Disc options for 32 Ford
I'm working on a 32 Ford pickup streetrod project that has a slightly modified split wishbone dropped Ibeam suspension setup and disc brakes from a mid-70s fullsize Ford. I'd like to find other disc brake options to use something more modern and plentiful in parts stores in the future while still retaining the rest of my front suspension setup.
Are there aftermarket spindles available that accept modern OEM disc setups?
Thanks in advance,
Mark
Old 01-07-2006, 08:38 PM
32 Ford Model B
re: Disc options for 32 Ford
Ok, I did some more research and found that lots of people are using 37-41 Ford spindles, and Pete & Jake offer brackets to fit OEM Chevy brakes. The spindles on our Little Truck aren't 37-41, and have a more rectangular bolt pattern. I may just keep the early 70s fullsize Ford disc brake setup that's already there.
Can anyone tell me why the 37-41 spindles are superior to others? I'll try to post a picture tomorrow of my setup and get some opinions.
This forum is going to be a great help as we build our rod.
Thanks,
Mark
Old 01-07-2006, 10:21 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Originally Posted by LittleTruck
Ok, I did some more research and found that lots of people are using 37-41 Ford spindles, Can anyone tell me why the 37-41 spindles are superior to others? I'll try to post a picture tomorrow of my setup and get some opinions.
Thanks,
Mark
There are two popular groups, the 37 - 41 Ford and the 42 - 48 Ford. The 37 - 41 are called round back and the 42 - 48 are called square back. Neither is superoir to the other...just different backing plates. There are kits galore for both types. I have the 42 - 48 square back on my 32. I have 56 Ford F-100 drum brakes ( a old popular 50's and 60's brake upgrade ) and the 56 F-100 backing plates are square so they fit better. I would have had to grind away some of the spindle on a 37 - 41 spindle for the F-100 backing plates to fit. The 37 spindles came with mechanical brakes. Ford went to hydraulic in 1939. In 1942, Ford came out with a square back backing plate ......which resists twisting on the spindle better than the round backing plate one... so....the 42 to 48 are actually the improved version ... for stock backing plates...
I have Wilwood disc brakes on my new under construction 32 Ford......
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Disc options for 32 Ford"
9 inch ford home made disc brakes zonk Suspension - Brakes - Steering 6 06-02-2006 12:31 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Disc brake conversion on Ford 9" shockers69 Suspension - Brakes - Steering 1 07-01-2004 10:26 PM
anyone know of a disc brake swap for 49' ford? Shoebox49' Suspension - Brakes - Steering 5 03-05-2004 10:18 AM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 05:48 PM
