Discharge fuel filter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2010, 02:41 PM
Can I mount a traditional (usual suction) fuel filter on the discharge side of the mechanical fuel pump on a SBC, to filter the gas before it enters the carb? I didn't know if they would break down and cause more problems or what type of filter do I need, right now I have a 3/8" hose barb on the pump leading into a 3/8 line going to the regulator. It's a low pressure Edelbrock pump. Thank you
Old 12-25-2010, 03:45 PM
General rule of thumb is you want as few connections on the pressure side of the fuel pump as is possible.
Old 12-25-2010, 04:29 PM
bondo's Avatar
Ayuh,... You want the filter Before the pump, to Save the pump for any Crap...
The check-valves in the pump are as touchy as any carb about Crud...
Old 12-25-2010, 10:54 PM
i've always understood it that you never want filters on the suction side of the fuel pump, the suction can collapse the filter media and cause starvation problems. always filter on the pressure side.
I had a filter on the suction side by the tank and it was causing me all kinds of headaches that went away after I got rid of it, and moved to a filter just infront of my regulator.
This pic here isn't the greatest pic for this, but you can see my regulator and filter setup, all mounted by the carb on the passenger side.
Old 12-26-2010, 09:16 AM
302 Z28's Avatar
A filter on the suction side of the pump is always a good idea. You must however use the correct filter. Not a pleated paper filter that can collapse. Use a sintered bronze filter or a filter with a fine metal screen that can be taken apart and cleaned if needed.
Vince
Old 12-26-2010, 10:59 AM
bondo's Avatar
Ayuh,... This is what We use on boats, 'n it's ALWAYS before the fuelpump...
Old 12-27-2010, 10:37 AM
if it was such a great idea, why is it that they aren't used in production? the filter is always on the pressure side. Even back in the carb'd days, the filters were AFTER the pump.
Old 12-27-2010, 10:55 AM
You have to realize that everything that is a on a car goes through a cost analysis.
If you can save even a penny in the cost of a part, used in making a car, you multiply that penny by the number of cars made using that part, and the auto company saves thousands of dollars.
Fuel filters are after the pump on modern cars for one reason. The fuel pump is in the gas tank.
Old 12-27-2010, 11:03 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
and those in-tank fuel pumps have a screen/filter mounted on the pump itself as part of the inlet to the pump (before)
Old 12-27-2010, 11:10 AM
airboat's Avatar
Yeah the in-tanks have a pretty effective sock. Most after-market fuel pump manufacturers will recommend a filter on the inlet side of the pump. The one Bondo posted a pic. of is inexpensive, convenient and large enough to do a great job. really need it especially with a vane type pump.
Old 12-28-2010, 12:03 AM
yeah.. that's why my 1972 Monte carlo had a fuel sock in the tank, and a filter _AFTER_ the pump. (from the factory)
if it was such a great idea to put it before, don't you think they would have?
it's much much harder to 'suck' then it is to 'blow' think about how little airflow you feel in front of the radiator fan, vs behind it..
Old 12-28-2010, 02:32 PM
Wiki Edits: 31
from the factory, some didn't even have filters, and just had the sock in the tank..most vane and rotor electric fuel pumps require filters before the pump... factory didn't do it because the sock was there
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 06:24 PM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 07:31 PM
fuel injected engine needs fuel filter autonut Engine 3 04-13-2008 08:54 AM
fuel filter before or after fuel pump? pi71 Engine 6 09-10-2007 12:41 PM
E85 compatible fuel filter, with fuel injection ripple Engine 5 05-10-2007 06:48 AM
