Disconnect of "Horn Relay" Config - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2012, 03:25 PM
64Joker's Avatar
64Joker
f I disconnect the entire "horn relay" unit/wire(s)/harness (including the "Bat" wire from the relay to the battery) will it prevent the ignition switch from starting the engine? Or is the "horn relay" wire configuration completely independent?
Make: Chevrolet
Year: 1964
Old 10-31-2012, 03:36 PM
Last journal entry: was hoping for better than this
model?
Old 10-31-2012, 03:39 PM
64Joker's Avatar
64Joker
Model
Model: Impala SS
Tran: 350 Auto
Engine: 327
Ignition: HEI
Old 10-31-2012, 04:00 PM
EOD Guy's Avatar
The horn relay is a buss bar for the fuse box, but I think there was a seperate wire that went to the ing switch. What are you trying to do..... prevent the car from starting or making sure it's elec safe?
Old 10-31-2012, 04:02 PM
64Joker's Avatar
64Joker
EOD Guy
Just making sure it's electrically safe! I don't plan to use the stock horn setup, or any horn for that matter. Cleaning up the wiring...
Old 10-31-2012, 08:20 PM
EOD Guy's Avatar
There should be a green wire that controls the horn relay it's self and a hot feed from the factory splice, via a fuseable link (short piece of wire that should be orange, and looks like it was spliced into the red wire) and the feed to the fusebox.
You can splice the orange and the red wires togeather, but don't get rid of the fuseable link unless you replace it with a Maxi-fuse. It the only thing that protects your elec system from a meltdown should a major short occur.
Old 11-12-2012, 07:55 PM
SSedan64's Avatar
This M.A.D. article & diagram should help, also has upgrade Info.
3-Pgs. >> http://www.madelectrical.com/electri...evymain1.shtml
Other Tech >> MadElectrical.com - Electrical Tech
Old 11-13-2012, 08:25 AM
64Joker's Avatar
64Joker
Ssedan64
[QUOTE=SSedan64;1610544]This M.A.D. article & diagram should help, also has upgrade Info.
3-Pgs. >> Catalog
Excellent document(s)! Thanks!
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
SBC "Rams Horn" Manifold Bolts- Size?? acr Engine 4 03-30-2005 08:49 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
