Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Disconnecting instuments in 1937 Buick
Old 06-25-2012, 02:19 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
Iím trying to remove the í37 Instrument cluster from my 37 Buick without damaging it.
1) Can someone tell me how disconnect the water temp cable from the instrument cluster?
2) The oil pressure line is also not obvious on how it is unhooked. It looks like a hex nut but did not readily turn and I do not want to damage the instruments. Is this a hex nut that crimps down on a flared tube?
Thanks,
Mutt
Name:	comp ins cluster.jpg
ID:	66320   Click image for larger version
Name:	Front water & gas comp.jpg
ID:	66321   Click image for larger version
Name:	Water temp comp.jpg
ID:	66322   Click image for larger version
