disfunctional door keys - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-25-2003, 05:10 PM
ponybuster's Avatar
keys again
Your idea sounds by far the best to me... how much should a kit cost?
and should the trunk, door, and ignition key all be the same??
because people have told me that.... but i have 1 key for the ingition and it seems that it fits into the door but wont turn
and the trunk key works, but doesn't even fit in the key hole
  #17 (permalink)
Old 08-26-2003, 12:44 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
A lock cylinder set usually comes with 2 door locks and 1 truck lock and 2 keys that are matched to the lock cylinders. The kit runs about $10 - $20. Personally who cares if you have to carry a seperate key for the ignition...Gm has done that for years
At least you'll be able to lock/unlock your doors.
Later,
WEIMER
  #18 (permalink)
Old 08-26-2003, 04:01 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
If you don't want to change out the cylinders, then go to a locksmith and he can cut a key to fit the door off of masters that they have.
Kevin
  #19 (permalink)
Old 08-28-2003, 01:58 PM
ponybuster's Avatar
Alright
Ok guys... i've opened my door up (wasn't hard at all) then i look inside towards the locking mechanism.... the rod isn't connected to anything
?? whats this mean
also i tried using the key in the lock cylinder and moving the latch up and down and it doesnt work the latch will move up and down but nothing happens? whats wrong??? please post guys!!!!
  #20 (permalink)
Old 08-28-2003, 05:59 PM
ponybuster's Avatar
New Lock Cylinders
I have made a decision to just go with what the last guy on the last post page said... just change the lock cylinders... the only problem is though...... i need to know how to get a lock cylinder out of the door? how do you get it out?
any posts would be helpful
  #21 (permalink)
Old 08-29-2003, 06:17 AM
EBlack36's Avatar
Rebuilt Excitment
Should be a litte "U" shaped clip or a nut on it.
  #22 (permalink)
Old 08-29-2003, 11:07 AM
Kevin45's Avatar
Ponybuster....Hook the rod to the latch. If it isn't hooked up thats why it isn't working.
  #23 (permalink)
Old 08-29-2003, 12:49 PM
ponybuster's Avatar
I did
i hooked the the rod to the locking mechanism already... it doesn't do anything
the key still wont turn
i'm thinking about changing the lock cylinder and transferring the tumblers
  #24 (permalink)
Old 08-31-2003, 12:40 PM
ponybuster's Avatar
what would you guys do
I decided to change the lock cylinders..... and i want to transfer the tumblers that way the old key works
good or bad idea????
  #25 (permalink)
Old 09-01-2003, 03:48 PM
ponybuster's Avatar
Problem Solved... thanks for all the help
I finally got to opening my door panel.... i took the u clip off the door and slid the lock cylinder out...
it wouldn't work at all before
so i took all the tumblers out and re did the cylinder exactly as it came out...... now it works (much oil and lube was used) 1 cylinder works perfectly the other only has minor turning issues but now i have doors that lock
thanks for all your posts and all the great help!!!
- a satisified poster
Name:	mustang close up front.jpg
