dish or flat top piston? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2009, 08:00 PM
I called a place about getting a short block. I have no core so any 350 would do. The engine specs I are for a daily driver.
282 crane cam
vortec heads shaved .020
what i want is around 9.5 c/r maybe a bit more. Definitely not more than 10.
They have a .040 over 4 bolt left hand dip stick block but it has dish pistons. I am concerned that I may not reach my needed c/r for cam (it matches my gearing). I wasn't sure if it would turn out to have too much c/r with flat tops. The bad engine in the car now has 11.5 c/r which wasn't good for daily driving (same heads). I know this is vague I am just looking for ballpark. If it ain't gonna work with standard dish pistons and I need the flat tops than so be it. I just want to run pump gas.
Old 08-13-2009, 09:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What you need to ask is, "What is deck height AND the part number and dish volume of the pistons in this engine?".
Do not say "I need an engine w/"xx" cc dished pistons", let them tell you first.
Old 08-13-2009, 10:03 PM
When I called I told them I wanted a 350 short block assembly that would get me around a 9.5 cr with 64cc heads or vortecs. Then he asked me if I wanted flat tops or dish. I went with dish because I wasn't sure about going to high with flat top.
I would rather have a soggy low end than I rattle can.
I was referred to go there from a member on this forum and their prices are pretty good. They aren't too far from me either.
350 Flat top pistons question DENCOUCH Engine 2 05-27-2008 09:22 PM
Which clay for measuring piston top valve reliefs? groundrail Engine 2 05-21-2005 03:43 PM
Difference Between dish and flat piston Parisienne70 Engine 3 02-15-2005 10:10 PM
Top piston ring gap readyeddie Engine 8 09-08-2003 12:54 PM
