Disk brake caliper & steering arm hitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2005, 12:56 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
1955 2nd series Chevy truck
I love working on my truck! Really...I get to find out all the little things you get to figure out. So here is my next hurdle.
I installed the PS box and hoses. I bleed the system and was really happy to get all the bubbles and noise to go away. So I go to put my disk brake caliper on and the caliper hits the new steering arm! I can't lean the caliper forward enough to get the top bolt in. I took some photos for all to see. I am going to have to grind off a little on the caliper and some on the new steering arm. The disk brake kit was from CCP and the PS was from Chevy Duty. Has anyone seen this before?
First photo is all the components on, second and third is where the caliper and steering arm hit. In the second photo the screw driver is where the bolt is supposed to be.
I think I will be safe taking metal off both pieces...but it anyone has any advice......
Name:	PS installed 3.JPG
ID:	5150   Click image for larger version
Name:	PS disk problem 3.JPG
ID:	5151   Click image for larger version
Name:	PS disk problem 6.JPG
Old 05-28-2005, 01:14 PM
gator412's Avatar
More pics
More pics to see the problem
Name:	PS disk problem 9.JPG
ID:	5153   Click image for larger version
Name:	PS disk problem 10.JPG
Old 05-28-2005, 08:09 PM
abstruse dutch uncle
So was this a problem with the manual steering too? Is this a problem with the disc kit, or a problem with the steering kit?
Pics dont aleways tell 1,000 words, so I'll go by what I think I'm looking at... it is a problem with the disc kit. I would have to assume the manual steering hooked up similar/same....
Can you swap the disc calipers and brackets left to right, re-run the lines/hoses, to put the brakes in front of the axle? Or is there a clearence problem there too?
Just throwin out ideas...
Old 05-28-2005, 11:31 PM
gator412's Avatar
I had the disk on the truck and was installing the power steering when this problem came up. I ended up grinding off a bit of the steering arm and the caliper. It didn't take much to get it to fit. So it is installed now. The hose is close to the steering arm but I don't see that it will be a problem.
Name:	Steering arm grind.JPG
ID:	5321   Click image for larger version
Name:	Caliper and steering arm grind area.JPG
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
disk brake swap CARGUY Suspension - Brakes - Steering 0 07-22-2002 01:52 PM
