-   -   Disk brake conversion for a 1953 3/4 ton pickup w/t Junkyard Parts (http://www.hotrodders.com/forum/disk-brake-conversion-1953-3-4-ton-pickup-w-t-64800.html)
YoungGunRodder 06-25-2005 06:28 PM
Hey All,
Is there any way to convert my stock front drum brakes (mby rear) to new style disk brakes with junkyard parts? I have a 1953 Chevy 3/4 ton pickup (3600) that is my first restoration project. I know there are conversion kits for the 53 Chevy truck but they are expensive and i am kinda on a budget.
I also don't want to do the whole front end mustang thing cuz i would like to restoration my truck but upgrade it a little. If there is anyone out there who could give me some advise it would help.
Deuce 06-25-2005 09:36 PM
:D
I do not have a good answer for you but as one of the Moderators here........let me be the first to WELCOME YOU........ here :welcome: :welcome:
DEUCE........
bluechev 06-25-2005 09:49 PM
it has been done. the guy who'd done it used to have a web page showing exactly what he'd done. there was a link to it on chevytrucks.org. i just found out it doesn't exist anymore. he used a 90's model 3/4 or 1 ton rotor & made a caliper bracket from 3/8 or 1/2 " plate. don't know what he did for bearings. i know this can be done! if you keep looking you'll find a way. then you can write back to the editor of classic trucks & tell him you're a real hot rodder & you can update your truck without all those mailorder kits they advertise in his rag!!
you are the guy that wrote them asking this same question right? i sure wasn't impressed with his answer.
robert
YoungGunRodder 06-25-2005 10:38 PM
No i wasn't that guy but when i do find a way to do it I sure will tell the magazines because all/most those kits they sell don't even work for a 3/4 ton 53.
At least i know there was someone who has done it before and it gives me confidence in my cause.
Dutchman 06-26-2005 06:25 AM
Maybe a couple links could help:
http://www.diynetwork.com/diy/shows_..._26881,00.html
http://web.ics.purdue.edu/~stanchfi/...ion-60-64.html
http://www.hotrodders.com/kb/suspens...iscbrakes.html
I have a couple friends that welded and installed S-10 brakes on their car. They can go to any part store to pick up replacement pads now.
Dutch
