Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 08-17-2004, 08:46 AM
Loup's Avatar
Loup Loup is offline
Disk brake conversion need help
Hello
I'm converting the front power drums to front power disks on my 67 Firebird. I didn't buy a kit so I replaced the booster/master cylinder (NAPA) and don't know what to do now with the actual distribution block to complete the conversion. Re-use it ? Throw it ? Get a later combination valve from a 71-later Firebird ? Get a Wilwood proportioning valve ?
I really need help with the valving system to complete the conversion. Keep the stock look is not important. Save money yes ...
Thanks a lot
Old 08-17-2004, 02:02 PM
stinky jinx's Avatar
stinky jinx stinky jinx is offline
Searching for horsepower
re: Disk brake conversion need help
I would suggest that you get the Wilwood ( or Baer.. they are all mostly made in the same plant), it is nice to be able to adjust your brake bias front to back. You can do it a couple of ways.....either pitch the proportioning valve (you might have to replace the line) or you can just gut the valve block and leave it in place.
I just did this on my 72 SS El Camino and I gutted the valve block and left it in place. I spliced a Wilwood proportioning valve into the rear brake line on the drivers side on the frame just before it goes up over the rear axle. That makes it convenient to reach down and adjust. If you need more info just ask.........jerry
Old 08-18-2004, 12:11 AM
jimfulco jimfulco is online now
If you want to go with stock-type stuff, Rick's has a lot of stuff for early F-bodies.
http://www.rickscamaros.com/cgi-loc...2a+1092 876061
Old 08-18-2004, 06:12 AM
yesgo yesgo is offline
abstruse dutch uncle
You wont need to gut the valve on a '67 Firebird. It used the same one for disc and drum. Keep it for the warning switch and get that adjustable rear valve.
If you drive in snow, or get bad front end brake-dive, you can get the stock style front brake 'holdoff' valve too.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
