disk brake needs / - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2011, 09:48 PM
StudebakerDean
disk brake needs /
Can a pro out there tell me what type of master cylinder I need to have lincoln versailles disk brakes in the back and s10 stock brakes in the front?
I heard disk brakes will require a different master cylinder than i have.
would love a schematic or diagram of what the rear lincoln disks should look like assembled, if its out there. all the articles I find have their photos removed.
im trying to get past a problem. ive got an s10 frame, ford leaf springs bracketed on the bottom, a versailles rear end. my brake assembly (which ive not exactly figured out how it goes together) hits the u bolt bracket on my leaf springs.
Old 07-04-2011, 12:45 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
You won't have to swap the master cylinder unless you put in bigger piston front brakes.
Use an adjustable proportioning valve.
Rich
Disk Brake 9 Inch Help Grouper Transmission - Rearend 20 09-28-2008 11:08 PM
Disk brake conversion 67F250 Suspension - Brakes - Steering 1 10-16-2003 10:32 PM
disk brake conversion a2b Suspension - Brakes - Steering 3 07-19-2003 04:09 PM
disk brake conversion 39rodder Suspension - Brakes - Steering 6 06-02-2003 08:54 PM
disk brake CARGUY Suspension - Brakes - Steering 1 01-03-2003 01:50 PM
