Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disk brake question...
Old 06-26-2011, 04:55 PM
timothale timothale is offline
Wiki Edits: 27
keeper needed
There is a U shaped keeper about 1 1/2 inches long that slides in between the caliper bracket and the caliper, It has a cresent cut out that the allen bolt tightens down to retain, Ford sliding calipers tend to wear out one side of the rotor, make sure the parts are clean and a light coat of anti seize lube . I think the front keeper should fit from the 70's mid size casrs if you can't find your missing parts.
