disk brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2004, 01:56 PM
New Member
disk brake swap
I'm working on a 67 mustang, converting to 4 wheel disks, efi 5.0l and T5 trans. For the rear disks I have a bracket that bolts to the rearend and uses a Caddy caliper +Lincoln rotor. My question is can I run a simmilar setup up front where a rotor slides over the stock drum brake hub [with drum removed] and a bracket bolted on for the caliper?
granada stuff is basically non-exsistent around here.
Old 02-12-2004, 01:04 AM
aka Duke of URL
Unhappy
You would need to find a MUSTANG 65/67 with KELSEY-HAYES four piston calipers, mounting brakets and rotors. They will work with your spindle (8 cyl). You can also go to 68/ single piston calipers if the car has the service upgrade spindles or you will need the later spindles.
