disk brake swap on 52 pontiac?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2003, 06:21 PM
suede's Avatar
I was wondering if anybody knows what spindles will go in to a 52 pontiac chieftain, to switch it to front disk brakes? My freinds told me that there is a spindle out there that will go in i just have to find out which ones will work. That is why i came too you guys, any help would be great.
Old 08-27-2003, 07:34 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
most likely you could use a disc brake kit for 49-54 chevy cars on your pontiac spindles since they're so much alike, unless someone know something I dont.. Get a street rod mag & call a couple of disc brake companies & they'd tell you for sure.........joe
Old 08-27-2003, 07:41 PM
suede's Avatar
thanks joe. thats what i have been thinking since the two cars are so alike. i want to get most the parts from the junk yards to keep the cost down you know! i cant afford to go buy one of those kits
Old 08-27-2003, 09:48 PM
Wiki Edits: 5
you'll have to at least spend $100-$150 for the ecno-installation kit from one of the many companies who sell them, RB Rod Parts
& Butch's Rod shop are 2 that comes to mind, where you get the plate that holds the calipor on & a race to slide over you spindle. The kit will tell you what other parts you'll need & that will work. hope this helps you more.........joe
Old 07-22-2007, 08:56 PM
GaryD's Avatar
Unfortunately, the Chev body is the same, but the frame and suspension are more on the order of the Olds and Buick, the chev spindles aren't the same. FatMan Fab has dropped spindles for it if you'd like to go the whole route. Scarebird Classic Brakes has a conversion kit that will adapt later model Pontiac Catalina discs to your stock spindles. They sell the adapter plate, you still get to rummage the junk yard to scrounge up the rest...
Old 07-22-2007, 10:39 PM
Wiki Edits: 5
ahhhhhhhhh GaryD did you even notice that the person asking the question has only 2 posts && that this post is almost 4 years old ~~>08-27-2003, 10:48 PM && the last time they were on the site was Last Activity: 08-28-2003 07:37 PM
, can ya digg a little deeper for some older ones ???
CHECK THE DATES B4 YOU POST
Old 07-23-2007, 06:27 AM
GaryD's Avatar
DOH! Guess maybe he got it figger'd out or gave up by now.
Wonder why it popped up in Todays Posts when I logged in last night. Oh well...
