If you are using an adjustable proportioning valve, throw the block in the parts bin. If your MC is on the fire wall, you should not need any residual valves, but if you are having to pump a couple of times to get a good high pedal (after bleeding), then put a 10 PSI residual valve on the rear line as close to the Mc as you can get it. If you have two lines coming out of your MC to the rear, plug one fitting in the MC , install the residual valve with line to the Adjustable proportioning valve and T to the rear wheels down stream where it is convienent.
Trees
