Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disk brakes conversion no pressure to back brakes
Old 04-16-2003, 07:08 AM
chevy1 chevy1 is offline
Some Proportioning Valves also required a special spring loaded clip to be installed on the little Button to pull it out of the valves groove so the valve could re-center itself. You don't use the spring's not going to center itself and you'll still only have brakes on one circuit. You'll center the valve by bleeding off some fluid to either the front or the rear lines depending on which side the valve slid over and it should be good to go!
