Disk brakes for Dana Rear-end - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 01:00 PM
Where can you find a disk brake conversion for a Dana rear end?
Old 05-24-2008, 01:37 PM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
What is your Dana in, (or out of)? As they were used by Mopar, Ford and I believe GM, the axle flanges may vary. My Dana 60 has "late big Ford" axle flanges for the larger Ford bearing.
Try Stainless Steel Brakes. They probably have a kit for you. I have a SS Brakes kit, and it is well made and was easy to assemble.
You said that you wanted a conversion, so if you are changing to disc brakes from drum brakes, you will also need to change the master cylinder also.
Start here:
http://www.ssbrakes.com/tech/
You can access a chart showing all of the different axle flange diagrams. Once you know that you can start your search. A lot of info on the website.
Hope this helps,
Steve
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 06:01 PM
54' chevy rear end gavinpierce Hotrodding Basics 6 02-13-2006 09:31 AM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
