Disk Brakes for Old Jeep Straight Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 11:11 AM
I inherited my Father's Henry J, on which he used a straight axle from a Jeep. This is equipped with drum brakes. I want to switch to disk brakes for added stopping power and parts availability. Does anyone have inormation on how to do this?
Thanks, Rob
Old 06-19-2006, 08:38 PM
powerrodsmike's Avatar
Wiki Edits: 161
If what you have is truly a straight axle out of a JEEP then this might not help....BUT, if you have an axle from a willys this may interest you...
About 4 years ago I bought a kit that would put a set of mid size GM calipers and 11" rotors on a 1933-42 willys axle. It was for a willys americar, not a jeep. There was a pair of brackets and some spacers and a sleeve that went over the spindle. I was told the americar axle was a common axle to use under the henry J . The man who made the kit no longer makes them, (I called him), and I tried to get him to send me a template of the bracket but he didn't have one any more.
When I was searching that kit out I found no one else who made one.
That doesn't mean there is no one else, I just did not find them.. ECI and Master power did not make them nor did IDA Automotive or the willys replacement parts guy in alta loma ca
I also did some research on putting early ford spindles (you can get brakes for those) on the willys axle but the ford kingpins were way too big. There would be nothing left of the axle if you drilled it out.
Now this may interest you if you have either the JEEP axle or the Willys.
There is a guy in Las Vegas named Ron Metcalf who will make a disc brake conversion for just about any car., All he needs is the spindle and steering arm. He has a website www.caddyclassicsbyrpm.com he also has an ad in hemmings. His website shows only the caddy stuff but he will do any car prior to 68 or so.
I have spoken with this man a couple of times but have never used his services so I can not say if he does good work or not. If you use his services please post back what you think. (or anyone else if they know him)
Or what about using a straight axle from a manufacturer like speedway or superbell? get the kingpin to kingpin measurements and start calling.
Hope this helps, mikey
BTW if I can find the template for the bracket I have all of the other measurements and bearing, seal #, parts # and instructions. I would send you all that stuff (free, this is HRBB) and you can have a local fab shop make it up.
M
BE different....ACT normal.
Old 06-19-2006, 09:43 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Some of the doge vans had a suitable axle and I am told that dodge rotors will fit so all you will need is some kind of bracket to attach the calipers..
of course you will need to change the M/C to something more suitable...
Sam
Rack&Pinion on old type straight axle austin Suspension - Brakes - Steering 53 01-29-2007 09:18 AM
disk brakes and everything connected oreosmuggler Suspension - Brakes - Steering 2 01-13-2006 12:45 AM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-19-2003 12:45 AM
straight axle falcon kalowry Suspension - Brakes - Steering 13 01-04-2003 04:26 PM
1938 chev - straight axle front end WILLARD(SONNY)STOTLER Suspension - Brakes - Steering 4 12-30-2001 04:26 PM
