disk brakes too hot
Well we just got back from our first 5 mile shake down ride- it is shifting much better and goes to 175-180 and stays there- the oil pressure is great- THS disk brakes are HOT- the rims are hot to the touch- the car stops good and straight- no pulling and we can smell the brakes just a little. the calipers are really close to the rims could this be why they are hot? I jacked up the car and put it in neutral and the rear tires are tight- pretty tight- could this be just new brakes? or maybe a bad M/C?- fun ride though
1964 Ford Falcon-302 cid- AOD trans- Disk Brakes all around |
Is it the master that originally had drum brakes, if so it probably has a residual valve built in and could be keeping the calipers partially engaged and causing the heat.You can pull the wheels and crack the bleeder valve and see if the pressure releases.
There are other things as well like internally collapsed hoses, master cylinder rod adjusted a little to long. Are the fronts ok? You will ruin the pads and rotors if you keep overheating them.
Artificial Intelligence is no match for Natural Stupidity Chet |
this is a dual bowl M/C for dual disk brakes-I am gonna wait till they cool down and take a look thanks-
roger that- thanks
Ok I just got back in- now the wheels have cooled off- they spin just like normal -any ideas?????
| disk brakes conversion no pressure to back brakes | shiner | Suspension - Brakes - Steering | 10 | 01-24-2011 11:09 AM |
| disk brakes | bwhokie | Suspension - Brakes - Steering | 2 | 02-14-2007 10:53 PM |
| Disk brakes | Les Forbes | Suspension - Brakes - Steering | 1 | 02-12-2005 03:01 PM |
| c-10 disk brakes | Skokz13 | Suspension - Brakes - Steering | 1 | 05-28-2003 03:44 AM |
| 72' Nova disk brakes | nlocke7458 | Suspension - Brakes - Steering | 8 | 05-03-2003 04:13 AM |
