disk vs. drum that is the question
im going back and forward between keeping my drums or converting to disk. what do you think?
does it stop ok?
do you have a bunch of extra cash you need to spend? does it stop ok? what, is the drum stuff worn out and you are trying decide the best way to spend the money? |
what, is the drum stuff worn out and you are trying decide the best way to spend the money?[/QUOTE]
Yes. and Yes. |
if its all worn out and you need spend some $$$ anyway
now would be a good time to switch over |
If it's your Falcon. Drums in front will stop it ok, but the brakes will fade down hills, so you have to shift down. If they are good or just need shoes, just spend $50 and put new shoes on. If you need drums, than it might be a good idea to upgrade. Drums are about $50 each for that, and for $150 your close to 1/2 the cost of a disc conversion on the front
Switch to discs - lots of reasons, but the fact that they will stop you in a shorter distance, are less prone to brake fade, pads wear at a slower rate, removes weight from the total of the vehicle are the first that I would consider. Then, if you have some aluminum wheels - they sure do look good through the spoke areas. You will probably need a proportioning valve, possibly a residual valve (though with a firewall mounted master cylinder it's not always needed) and a smaller piston but dual master cylinder - good time for that upgrade from the fruit jar single if not already done.
didn't know that '66 was a changeover year for the brakes. I knew the interior was a bit diffrent than '67-'69, and the grilles changed every year... Wish I still had my '67..
In any case. www.discbrakeswap.com has everything needed for the granada swap, the last car to use the Falcon suspension, which had decent disc brakes on the front |
Ford dropped the loadomatic distributor for '68. Gave it vac and mechanical advance after that.. Might have been a truck or base model car in the lineup before '68 to still have a single M/C..
| 66 Ford...drum to disk help | svo fatboy | Hotrodding Basics | 3 | 03-10-2011 01:12 PM |
| disck/drum to disk/disk | tomthecomic | Suspension - Brakes - Steering | 5 | 10-29-2007 08:53 PM |
| disk brakes and drum | Mrwood | Suspension - Brakes - Steering | 27 | 01-09-2007 10:52 AM |
| Swap Drum to Disk Brake | Ratoflic | Suspension - Brakes - Steering | 8 | 02-17-2006 11:24 AM |
| Dana 35 drum/disk swap question | Sixshooter | Suspension - Brakes - Steering | 1 | 11-19-2005 10:58 PM |
