Disks without power??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2007, 07:46 PM
Hi'
I have a 2500 lb car with corvair ifs ,10" gm rear with drum brakes all around .I am thinking about converting the front to disks .Will the disks work ok without power assist,and what kind of master cyl would be reccomended?
Thanks
Old 11-11-2007, 08:11 PM
I believe that some of the 60s Corvettes (427-435s maybe) had manual disc/drum master cylinders.
Shane
Old 11-11-2007, 08:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
IIRC the '60s Vettes had 4 piston fixed calipers all the way around. But yes, they did have a manual brake option.
If you are using some GM midsize calipers and you keep a 1" master and a 6 to 1 pedal ratio you will have ok braking. the pedal will be stiff, but it'll stop a light car for most all of your braking needs..
I just took apart the brake system on a 40 Ford steel car with all the heavy accessories, AC, 9" rear, 351W and a bunch of stereo and power steering and carpet, sound deadening, ..(heavy for a 40 ford)with 9.25" rotors, MII calipers,(I need to check the piston size), some 10" rear drums and a 5:1 pedal ratio with a 15/16 bore master cylinder.
Those brakes were OK, but the owner didn't like the way it stopped....stiff pedal and marginal stopping power.......So it got an upgrade.
There is another truck in my shop with some 11" rotors, GM metric calipers, (IIRC those are 2.375 pistons),10" rear drums with 15/16" wheel cylinders, a 6:1 pedal and 1" master cylinder.
That truck stops ok, but again, the pedal is a bit stiff.
So yes, you can get a manual disc system to work quite adequately,,especially in a 2500 pound car, but unless you have a way to get a numerically high pedal ratio and still have enough volume in your master to run those big pistons, you will have a stiff pedal. You can go to a smaller MC for a , but then you run out of fluid volume.....catch22.
The bad part about manual discs is that in the event that you need a bunch of brakes, you'd better have a BF leg. Discs are not self energizing, so a panic stop is a strenuous event.
That is one of the main reasons the majority of disc/drum systems are boosted.
Hope this helps, Mikey
BE different....ACT normal.
Old 11-11-2007, 08:44 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ford on its earlier big vans had disk drums and a manual M/C option..Can't say how it works as my rodster is not road worthy yet but tha tis what I am doing...
Sam
Old 11-11-2007, 08:51 PM
Thanks
I just don't want that big power booster in my engine compartment maybe I'll think about an under the floor set-up,or the corvette mastercyl I have to watch the budjet,but I do want good brakes It stops good with the drums,but I'm going from a 4-cyl to a V8 and I thought maybe the disks would be better???
Old 11-11-2007, 08:59 PM
Wiki Edits: 161
Originally Posted by yragat
Thanks
The corvette master is not all that special, the manual one is a 1" bore with 2 of the same size reserviors..In fact, the springs inside may be better suited to a 4 wheel disc system.
Later, mikey
Old 11-11-2007, 09:31 PM
Have you thought about Hydroboost? are there any production 4 wheel disc mastercylinders thatl'll work with hydroboost?
Shane
Old 11-12-2007, 04:58 AM
I don't even know what hydro boost is. Is it something new and is it expensive? If the vette master cyl isn't anything special what others would u suggest?
Old 11-12-2007, 05:37 AM
aka Duke of URL
Non-Power Disc-Drum was a common option (over four wheel drum) in the Muscle Car Years, mainly because of cost (booster option) and low engine vacuum.
IMO, there is not that much extra pedal effort required and it makes for a cleaner/cheaper installation.
Just pay attention to the info already provided as to MC type, valving, etc.
Old 11-12-2007, 08:21 AM
Thanks, good you mentioned about low vacumn I don't think I'll be having much with the cam i'm going to use
Old 11-12-2007, 08:53 AM
31 five window
Last journal entry: grill and rear end
Everybody made good points so consider them all. Hydraboost is far from new,it is power brakes run by the power steering pump instead of vacuum booster,hydraulic=hydra,hope this helps you.My son in law"big brian"and I and others built his 1965 big block chevy truck,it had original manual brakes,we changed the whole front suspension from a 81 c10 W/disc front and made our own rear disc conversion later. He wanted a clean firewall also,we put the 81 master cyl with no booster w/stock pedal assembly.It worked very well with and without rear discs,and I am no where near as big as Brian.
Old 11-12-2007, 10:08 AM
I don't have power steering any way so that wouldn't work for me
thanks
Gary
Old 11-13-2007, 09:26 AM
My son's 57 Chevy BelAir 2door sedan has discs up front(early Chevelle) and no power assist. None of us have had any problem getting it stopped even in a few "panic" stop situations.
Of course, we don't have any problem with the stock manual steering either. My wife has driven the car and had no complaints.
What do you reckon all those old Grannys did when cars had none of this power stuff? I'll tell you, they got in the car and drove it everyday because that was what they had.
Old 11-13-2007, 09:44 AM
Sounds good to me!
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
