dist. gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2007, 12:36 PM
runn141's Avatar
dist. gear
i have a 95 350 with a factory roller cam, i was wanting to put an 85 hei distributer in. would i have to change the gear from the 95 to the 85.
Old 12-20-2007, 12:54 PM
You need a Melonized gear as used on the 95's distributor. See your GM dealer.
Bogie
Old 12-20-2007, 06:51 PM
Part number 10456413, costs ~$30.
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 01:31 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
Sheared distributor gear pins and HV pumps adsala Engine 1 04-12-2004 05:36 PM
Bad gear drive? Marcus Engine 0 03-14-2004 04:44 PM
