Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dist gear for mellings cam?
Old 05-09-2012, 02:55 PM
Catfish11 Catfish11 is offline
I "think" I should be ok but want to ask. Will this gear thats on this dist be ok with a stock mellings cam? The cam is a pre 90 style hydraulic flat tappet. Using 10w30 VR1 conventional oil. The engine is stock with a stock oil pump and will not see 6000 rpm , its a low rpm engine. Should I do this modification to the shaft?
http://www.hotrod.com/techarticles/e...fication_tech/
Also the instructions also call to remove the oil filter bypass, how do you do this?
I have swapped a few dist and dont remember all this stuff.
Thanks , its a new engine and dont want to shear the gear off
http://www.jegs.com/i/Proform/778/66...oductId=746781
Proform 66940 - Proform High Performance Distributors & Accessories Details
GM HEI Distributor
without Coil
Fits '55 - '82 Chevy small block and big block engines. NO rebuilt components. It has a high-performance control module, a hardened gear, a capacitor that prevents radio static, a high-dielectric cap with brass terminals, and a premium motor
