Dist gear for mellings cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 02:55 PM
I "think" I should be ok but want to ask. Will this gear thats on this dist be ok with a stock mellings cam? The cam is a pre 90 style hydraulic flat tappet. Using 10w30 VR1 conventional oil. The engine is stock with a stock oil pump and will not see 6000 rpm , its a low rpm engine. Should I do this modification to the shaft?
http://www.hotrod.com/techarticles/e...fication_tech/
Also the instructions also call to remove the oil filter bypass, how do you do this?
I have swapped a few dist and dont remember all this stuff.
Thanks , its a new engine and dont want to shear the gear off
http://www.jegs.com/i/Proform/778/66...oductId=746781
Proform 66940 - Proform High Performance Distributors & Accessories Details
GM HEI Distributor
without Coil
Fits '55 - '82 Chevy small block and big block engines. NO rebuilt components. It has a high-performance control module, a hardened gear, a capacitor that prevents radio static, a high-dielectric cap with brass terminals, and a premium motor
Old 05-09-2012, 03:06 PM
As long as your camshaft isnt a roller cam(it isnt) made from billet stock, you will be fine. dont need the dist. modification either. That article and mod is about roller camshafts.
Just make sure you have enough ZDDP additive in your oil, and follow proper camshaft breakin procedures.
dist. gear runn141 Engine 2 12-20-2007 07:51 PM
302 dist. driveshaft gear and c4 question 70chevyc10 Engine 1 06-16-2007 06:33 PM
Bronze Dist Gear markn Engine 3 08-01-2004 09:55 PM
No more dist gear problems! Knobie Engine 1 10-16-2003 06:46 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 05:50 AM
