Has the intake or intake faces been cut? The distributor might be bottoming out on the oil pump drive as opposed to the manifold.
The way to check this is to drop the distributor in without a gasket. It should sit down all the way without any gap. If it doesn't then you need to use a spacer.
BSE Racing Engines |
I think I may have to shim between the dist & the block. Just remembered the dist was sitting on a little piece of the valley pan gasket and I cut that little piece of gasket off so the dist would set flush on the block.I'm going to take the holddown loose and see if I have any gap between the dist and block & if so them I will have to shim it
Does that sound right? |
Take out the o-ring as well to see if there's something holding it up.
How easy does the distributor rotate on it's own?
Fact is stranger than Fiction |
| Advancing and Retarding Timing | Linez35 | Hotrodding Basics | 3 | 09-18-2011 05:10 PM |
| Retarding my cam | crankshaft3rd | Engine | 10 | 01-22-2011 02:37 PM |
| retarding cam timing | fiscus | Engine | 9 | 01-09-2004 02:18 AM |
| Retarding initial timing. ( try this again ) | KeithB123 | Engine | 17 | 12-09-2003 04:35 PM |
| changing from points dist. to electornic dist. what to change? | IHAVECHEVYPARTS | Electrical | 1 | 12-21-2002 09:20 AM |
