Distance between rear shock tabs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2013, 08:56 AM
andrewakessler's Avatar
I'm preparing to set my cab and engine onto the frame over the next couple weeks.
Before doing this, I wanted to install a set of rear mock-up shocks (purchased from Speedway) to help determine the ride height. The issue I'm running into is I'm not sure how much space I should leave in-between the shock tabs to account for a shock bushing. The shock eyelet is a 5/8 with a 1/2 bearing.
Looking at the universal bushings from Energy Suspension (Energy Suspension Parts - Shock Eyes), there are multiple lengths. Is there a general standard for shock bushings I should adhere to?
Thanks,
-A
Old 08-21-2013, 09:21 AM
I don't understand your ? , Shock eyes are 5/8 w/ 1/2 bearing ??? so you're using bushings or bearings????
dave
Old 08-21-2013, 09:33 AM
Hi Dave,
The mock-ups have a 5/8 eyelet, but also came with a 1/2 sleeve (I called it a bushing)
http://www.speedwaymotors.com/Coil-O...ool,57416.html
Thanks,
-A
Old 08-21-2013, 12:21 PM
O.K. just mock-up shocks [I use a piece of flat stock w/holes on each end , you probably should have your shocks so you know how big the bushings are , you must be mounting in "double shear".
dave
47-53 rear shock mounts Prof. T. Soggmeyer Suspension - Brakes - Steering 0 01-27-2012 02:14 PM
rear shock location racer rick Suspension - Brakes - Steering 8 11-26-2007 06:23 PM
Frame to Rear Drum Brake Distance, '47 Chevy Fleetline djjc76 Suspension - Brakes - Steering 7 06-13-2005 01:53 AM
rear shock problems 49olds Suspension - Brakes - Steering 2 05-01-2005 11:33 AM
rear shock angle zonk Suspension - Brakes - Steering 8 04-14-2005 08:11 AM
