Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distrbutor Swap Help
Old 11-01-2012, 07:36 AM
cdminter59 cdminter59 is offline
Distributor Swap help
Here is an article to read before you attempt to swap your distributor. http://www.crankshaftcoalition.com/w..._a_distributor Check out these caps to see if it is something you can use. Davis Unified Ignition Cap and Rotor Kits 36100BK - SummitRacing.com or Summit Racing® Distributor Cap and Rotor Kits SUM-G5225 - SummitRacing.com. The only difference is the type material the caps are made of.
The Following User Says Thank You to cdminter59 For This Useful Post:
wrb36usa (11-01-2012)
