Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distrbutor Swap Help
Old 11-01-2012, 08:44 AM
wrb36usa's Avatar
wrb36usa wrb36usa is offline
Originally Posted by cdminter59 View Post
Here is an article to read before you attempt to swap your distributor. Check out these caps to see if it is something you can use. Davis Unified Ignition Cap and Rotor Kits 36100BK - or Summit Racing® Distributor Cap and Rotor Kits SUM-G5225 - The only difference is the type material the caps are made of.
Thanks, CDMinter59. Great Web Site info on the swap. Also those caps looked like they my work, but I will have to check what type of distributor they go on. You guys are really coming up with good info.
