Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distrbutor Swap Help
Old 11-01-2012, 01:38 PM
cdminter59 cdminter59 is offline
Distributor Swap Help
Davis Unified Ignition Cap and Rotor Kits 36100BK - SummitRacing.com or Summit Racing® Distributor Cap and Rotor Kits SUM-G5225 - SummitRacing.com. These distributor caps and rotors fit the GM HEI distributors. They replace the coil in the cap style distributor cap. You will have to have an external coil.
The Following User Says Thank You to cdminter59 For This Useful Post:
wrb36usa (11-02-2012)
