Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distrbutor Swap Help
Old 11-02-2012, 03:52 AM
wrb36usa's Avatar
wrb36usa wrb36usa is offline
Originally Posted by cdminter59 View Post
Davis Unified Ignition Cap and Rotor Kits 36100BK - or Summit Racing® Distributor Cap and Rotor Kits SUM-G5225 - These distributor caps and rotors fit the GM HEI distributors. They replace the coil in the cap style distributor cap. You will have to have an external coil.
These may do the trick, CDMINTER59. I will check them out.
