Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distrbutor Swap Help
Old 11-02-2012, 02:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you've not left yet...
Originally Posted by wrb36usa View Post
I have a '49 Willys Jeepster Street Rod that has been channled 5 inches over the frame and the HEI Distributor is to tall. I have never changed out a distributor before and need help. Does anyone know the correct procedure for swapping out a HEI distrubutor for a stock one, or shorter one, on a '77 Chevy 305. The HEI is is to tall and in the way of an aftermarket electric wiper motor I am using to replace the old vacuum motor.
One option is a MSD p/n 84891 dist. which has both a crab cap and a magnetic pick up. It requires an ignition box because it only contains a magnetic pick up (no module). More details: http://www.msdignition.com/Products/...stributor.aspx
Skip White (and possibly others) sells a small cap HEI that's a stand alone, self contained unit.
