distrib question: vacuum vs mech advance
Stupid question of the day:
What role does the vacuum advance play when your distrib has weights on it to advance it? I found a crack in my vacuum line. Dont know how long its been there. How can I tell if my vacuum advance is even working? Can I use my timing light to watch it advance with and without the vacuum hooked up? |
Frisco, then why is there the vacuum advance? How exactly does it help with gas mileage if, when under load and at high RPMs with little vacuum, it gives away? Can you explain this?
Thanks! ![]() 78SilverShark |
Advance is there to increase power without detonation problems. When under cruise or really light throttle the air flow through the carb will generate vacuum that pulls on the canister, advancing timing for better fuel efficiency. When you step into the throttle, the vacuum will decrease in the dist. due to the sudden momentary loss of vacuum in the carb, this will retard timing and prevent detonation under loads, saving the engine. You must have a way to increase timing when there isn't a vacuum signal to the canister under load to allow earlier spark timing to compensate for rising engine RPM and increase drivability. That's where the mechanical advance will come into play. Seems alot people seem to get confused as to which timing measure is the primary advance mechanism, the vacuum advance. The mechanical advance is there to help support the vacuum at times where vacuum isn't available. The trick is with Mechanical timing can only be read at idle because there will be no vacuum to tell the vacuum advance what to do. Unless you hook the canister up to full timed vacuum port, but then you would be defeating the purpose of the timing retard feature under higher loads, which would allow less use of mechanical timing. I hope this explains well enough.
