distributer on 5.7chevy - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-30-2010, 05:27 AM
gmc1990rodder's Avatar
Thank you a lot !!! This is very helpful info! Like I said in my profile I'm new at the sbc builds for hottrodding! Most of my skills are from 4x4 apps on toyotas pre 1992, so all the help I receive here is useful!! Thanx to everyone
  #17 (permalink)
Old 09-30-2010, 07:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Man, are you in for a pleasant surprise!
Like has been said, the EFI-compatible distributor relies on the computer to select the correct timing for the conditions. Without the ECM, the distributor would not have been able to give you anything even close to what's needed w/a Thumper cam.
BTW, which one of the thumper cams did you put in it? I hope it was the smallest. Also, you'll get (IMO) a better tone from the exhaust if you add a connection between the two sides. Put it after the collectors and before the mufflers. You want the mufflers as far rearward as practical.
  #18 (permalink)
Old 09-30-2010, 07:43 AM
That's good! I can't wait, I know this engine has more power than I have experienced so far! I already have the distributor ordered so it should be in soon I hope. And I did install the smallest of the thumper cams! With the pipe connection, is this like an "H" pipe?
  #19 (permalink)
Old 09-30-2010, 09:52 AM
randolphi's Avatar
Distributer change--?
The distributer, I believe you have, only works fully with the computer, controling your advancing, but even if it works to run the engine, the performance is being severely hampered.
I found this link for a performance distributer, at malloryperformance.com
85 Series
(THEY HAVE OTHERS TOO!)
DIST,CHEV STREET HEI W/COIL
  #20 (permalink)
Old 09-30-2010, 10:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes. The exact placement isn't all that critical, IMHO- I would place it where it was convenient and after the collector, etc. as was said above. The diameter doesn't even have to be the same as the primary pipes, but closer to it is better than farther from it, size-wise.
newer chevy distributer in older chevy car,what are these four plugs? gearjammer38 Electrical 11 08-09-2010 10:15 AM
i think i screwed up the distributer help needed. thelasthallow Engine 25 08-15-2009 01:46 PM
bad distributer bearings? 1quiknova Engine 1 08-28-2005 02:00 PM
I've got a ? about distributer placement. bowtieorbust Engine 1 02-29-2004 08:35 PM
Mallory Distributer Advance morenbd Electrical 6 01-23-2004 11:11 AM
