Allright, I was all excited to have the new motor fired tonight and now I'm screwed. Or so it seems. Here's the background:
I rented an oil pump primer from the local parts store. It wouldn't engage and, on closer inspection, I noticed that the "key" that engages the oil pump shaft seemed to be way big. I compared the primer to my oil points distributor and saw that the points distributor key was much smaller. I cursed the Taiwanese engineer who designed the oil pump primer I rented, then had a buddy lathe off the cam teeth on my old points distributor (I was running a Mallory HEI on the old 307), then primed 'er up. My life was good.
I set the valves and did some other stuff. When about to drop in my HEI, I couldn't get it to seat. No biggie, right? Wrong. No matter what, I couldn't get the HEI to engage the oil pump shaft. Then I turned it over. Crap. It's got the much bigger "key," just like that tiawanese-made primer!
Looks like the problem is my oil pump shaft, not the distributor! So. . . . other than pulling the motor and replacing the oil pump shaft (I don't know why this is an issue, by the way, since I just got a standard chevy hardened shaft) what are my options?
I noticed they make .500 and .491 distributor gears. Can I just swap out the gear? Can I find an old points distributor (one without the cam teeth ground off) and swap out the gear from that?
Sorry about length, but I figured the whole story might be helpful. Thanks in advance!!!
