distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2008, 07:25 PM
distributor
can i put a distributor out of an '88 350 into an older 350 like '70 something i realize that i will most likely need the computer but i'm gonna put the tbi on too so it will be there i just need to know if the distributor will work
Old 10-12-2008, 07:47 PM
BOBCRMAN@aol.com's Avatar
The distrib will work fine. The problem you will run into is the pre-87 engine will have the wrong heads for the throttle body intake. You will need 87-later heads.
Old 10-13-2008, 06:30 PM
yes i realize that i'm gonna make an adapter plate to go from four barrel to the two barrel tbi, but yes thank you for the answer, i appreciate the knowledge
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Distributor Installation & Firing Order leejoy Engine 9 01-05-2006 03:18 AM
Distributor Drifting JamesRS Engine 4 08-18-2005 05:00 AM
distributor guchow Engine 4 11-10-2004 02:30 PM
