Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor ?
Thread: Distributor ?
Old 04-30-2012, 07:00 AM
delawarebill's Avatar
delawarebill delawarebill is offline
idle problem
your right...if u have a bad module it won't run.. at idle ur wt's should be closed up.. they may be sticking but thats really easy to ck.. pull the rotor and flip them out an see how they return. but i'd be look'n at the carb.. u may need a spacer to keep the heat off the carb... pull the idle screws and spray some cleaner in... just make sure u count the turns IN before u remove them.
