Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor ?
Thread: Distributor ?
Old 04-30-2012, 07:44 AM
406MOUSE 406MOUSE is offline
Originally Posted by delawarebill
your right...if u have a bad module it won't run.. at idle ur wt's should be closed up.. they may be sticking but thats really easy to ck.. pull the rotor and flip them out an see how they return. but i'd be look'n at the carb.. u may need a spacer to keep the heat off the carb... pull the idle screws and spray some cleaner in... just make sure u count the turns IN before u remove them.
Well I do have a demon 750 carb mechanical I wonder if it is even working properly with aupll the bad things I've heard. I jus figured that it might be ok sense im able to drive the car but it just seems to idle fine when it wants I do have a 1 inch spacer.
