distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2009, 08:33 PM
distributor
anyone heard of ati or ait distbutor? , trying to find a good brand.
Old 06-03-2009, 09:06 PM
302 Z28's Avatar
Any brand but Accel IMHO.
Vince
Old 06-04-2009, 11:51 AM
Irelands child's Avatar
If the part has Accel on it - I WILL NOT use it. The were once a good independent company, then Mr Gasket took it over (as it did with Mallory) and turned the name into junk. It was again spun off a short while back - so don't expect much improvement for a while, if ever. Myself, I stick with MSD, who in the last year or so was, I think, also sold, but I believe that it's still a pretty good product.
Your question about ATI - I did a quick Google - and the only real items found were transmission parts and dampers
Dave W
Irelands child
Old 06-05-2009, 06:12 PM
How about GM - as in stock HEI? I've never understood why people pay hundreds of dollars for aftermarket distributors that are exactly the same as stock. Change the ignition module or coil if you want, advance curve kits are cheap also. The aluminum housing and steel shaft won't be different in the expensive aftermarket unit. You can shim the shaft to eliminate end play and even replace the bushings if you feel the need (though another stock housing would probably be cheaper).
Old 06-07-2009, 09:03 AM
good looking ,thanks
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Need help with intake manifold brad1 Hotrodding Basics 20 03-30-2009 06:49 AM
Distributor Drifting JamesRS Engine 4 08-18-2005 06:00 AM
starting problems lori-due Electrical 11 11-18-2003 03:00 PM
