distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2010, 06:20 AM
distributor
maybe you can give me some tips. I have a1970 buick 455, I installed a msd pro billet distributor and problaster 2 coil a year ago. after the change from original distrubutor start up and performane been great. my problem is ,last week i took it for a ride, then was horseing around by hitting the gas up and down to make the front end lift up. well that when the car backfired and shut off. i tried stating but just backfired and wouldnt start, like it was out of time. well i was worryed that i messed up the distributor gear, witch it what happen to the original. i pulled it out the dist gear and cam gear look great. i reinstalled to same location and still bacfired and would not start, i then started to move the distributor and it started once for a few seconds and shut down. i moved in several location jstto try to fire it up, but the only thing i got was backfire, My disributor was lock down good and ran great and was still tight before i removed it. somhow it sounds like the timming is way off or can it be a coil or plugs that just decided not to work ? what could of i down by hiting it down to jump up the front end, i thought i flooded it originally. its a 1970 455 530 hp ans 600 tourque. do you have any advise, by the way i check coil with ohm its shows ok, but maybe its not putting out full voltage.
thanks
Old 09-06-2010, 09:55 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
That seems like the timing chain skipped a tooth or more.
vicrod
Old 09-06-2010, 03:46 PM
T-bucket23's Avatar
Wiki Edits: 26
Check the timing with a light while cranking. You may have jumped the timing chain or al the fuel sloshing may have hurt the needle and seat or dislodged some crap and plugged a jet or something. Before you do anything else you need to make sure the timing is correct. You also could have pinched or bent a fuel line. Eliminate things one at a time until you find the issue
Chet
Skip White 65,000 Volt Distributor Revealed Jr. Mechanic Engine 20 04-02-2015 05:00 PM
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
HEI Distributor Swap for a 4.3 knothead Engine 8 05-10-2010 02:27 PM
Distributor Drifting JamesRS Engine 4 08-18-2005 05:00 AM
