Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 10:08 PM
Gotta-love-Ford's Avatar
Distributor
Hey guys and gals. I have a 1964 f100 with a straight 6 223 in it. The problem irises with the distributer. When I got the truck the distributer was pulled from the engine and sitting in the cab. I have cleaned it up and fixed it all up but I donít know how to put it back in. I know how it fits but I donít think you can just put it in due to the timing of the engine. Please help..
Engine is complete except for distributer.
Old 04-15-2013, 10:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Much of the info here applies to any engine.
Basically, you want to find TDC of cylinder #1. Then orientate the rotor to match up to where terminal #1 of the distributor cap is at. Then wire the cap by the firing order in the correct direction of rotation.
Old 04-16-2013, 07:12 PM
Cape Cod Bob's Avatar
http://www.oldcarmanualproject.com/t...re5765-180.jpg
Old 04-16-2013, 07:26 PM
Bring up the #1 cylinder to the top position. Be sure it is the compression stroke. Both valves closed. You can tell this by removing the spark plug and put your thumb over the spark plug hole to form a tight fit and feel pressure as the piston comes up. Or you can remove the valve cover and watch the valves for that piston #1 closest to the front of the truck. They should both be up. Yiou can crank it around a few times to see how thy operate.
If you have not run this motor in a long time it may be a good idea to spin the oil pump with an old diistributor shaft conected to a drill to get the oil around to everything.
After you gt the #1 piston to TDC on the compresson stroke you can drop the dizzy in. With the dizzy cap off and the rotor in place you want the rotor to be facing the #1 plug wire. It may not be all that important where that is unless you need room to turn the dizzy to fine tune the timing.
Keep posting here until you get it fired. May take several times as even some of the best guys on here get it wrong sometimes. BTDT Luck
Old 04-22-2013, 09:06 PM
Hey guys, thanks for replying. I took out the sparkplug and found the tdc of the first cylinder and slid in the dizzy in place (Iím barrowing your term Cape Cod Bob)I replaced the sparkplugs, wires and all that jazz and am know trying to figure out all the wiring that runs along the firewall since it was in the cab all hacked up. Iíll try to fire up here soon and post some pics or a video thanks for all the help
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
Distributor has a tube running along side of the distributor? sscardino Hotrodding Basics 17 01-18-2012 07:25 PM
Distributor Hick_101 Hotrodding Basics 9 01-14-2012 06:11 PM
distributor TX_bowtie_devil Electrical 5 03-01-2006 06:37 PM
distributor's robbysapien Engine 6 10-19-2003 06:50 PM
