-   -   Distributor (http://www.hotrodders.com/forum/distributor-86743.html)
hwyhog 04-12-2006 05:07 PM
Distributor
Hey all,
I have a newly rebuilt ford 460. It has a Proform distributor with the magnetic pick-up--not points. There are 3 wires coming out of distributor...black, blue and red. My question....do I need to have an ignition box to run this or can I just wire it to the coil. I'm thinking black (ground), blue to (-)side of coil and red to (+)side of coil???
Any comments can also be e-mailed to Lisa2369@juno.com
thanks,
James
OneMoreTime 04-12-2006 06:28 PM
Try this
Go Here For the tech on that dizzy..
Sam
hwyhog 04-13-2006 07:39 PM
distributor
Thanks for the responses. Believe it or not, I called Proform directly and their tech support could NOT tell me what the wires were coming out of the distributor...as far as which is positive and which is negative. Again, I have a ford 460 with a proform distributor with the magnetic pick-up inside. ( their is no coil or any module on the cap. Does anyone know about this distributor? It has 3 wires coming out of it: RED, BLUE, AND BLACK.
thanks again,
James
jim.. 04-14-2006 09:48 AM
Unless your distributor has points in it,you will need the proper ignition module.
