Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2006, 06:07 PM
Distributor
Hey all,
I have a newly rebuilt ford 460. It has a Proform distributor with the magnetic pick-up--not points. There are 3 wires coming out of distributor...black, blue and red. My question....do I need to have an ignition box to run this or can I just wire it to the coil. I'm thinking black (ground), blue to (-)side of coil and red to (+)side of coil???
Any comments can also be e-mailed to Lisa2369@juno.com
thanks,
James
Old 04-12-2006, 07:28 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try this
Go Here For the tech on that dizzy..
Sam
Old 04-13-2006, 08:39 PM
distributor
Thanks for the responses. Believe it or not, I called Proform directly and their tech support could NOT tell me what the wires were coming out of the distributor...as far as which is positive and which is negative. Again, I have a ford 460 with a proform distributor with the magnetic pick-up inside. ( their is no coil or any module on the cap. Does anyone know about this distributor? It has 3 wires coming out of it: RED, BLUE, AND BLACK.
thanks again,
James
Old 04-14-2006, 10:48 AM
jim..'s Avatar
That 6 Cylinder Guy
Unless your distributor has points in it,you will need the proper ignition module.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Distributor Installation & Firing Order leejoy Engine 9 01-05-2006 04:18 AM
Distributor Drifting JamesRS Engine 4 08-18-2005 06:00 AM
distributor guchow Engine 4 11-10-2004 03:30 PM
