-   -   distributor cap knocking (http://www.hotrodders.com/forum/distributor-cap-knocking-182723.html)
h20l 08-14-2010 09:32 AM
What would cause knocking from inside a msd distributor cap, does not do it at idle. motor is a gen. v with 781 heads and a 554 lift cam. can someone help figure this out?
eloc431962 08-14-2010 12:32 PM
Either the cap is not fully seated, or it is the rotor is not seated. Check these things .JMO How old is the distributer ? It could be shaft play as well or just worn.JMO
Cole
