Distributor chose? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 01:15 PM
Distributor chose?
I'm building a 408W stroker with 3 duces and I'd like some suggestions on what distributor to use. I'm wanting to keep it simple, distributor and coil.
Thanks for your suggestions!!
john
Old 08-07-2012, 06:11 PM
EOD Guy's Avatar
I use a Mallory, I like it.
Old 08-08-2012, 04:24 AM
Using a GM HEI with the coil in the cap is very common, and Ford conversion distributors are available. Everything is in one package and you only need to connect up one power wire to the distributor. My understanding is that the Ford Duraspark is also simple to install.
Bruce
Old 08-08-2012, 02:49 PM
gto_ron's Avatar
I like the HEI also as long as you upgrade it with better rotor button and cap. If you have a stock distributor and want to maintain stock appearance the Pertronix solid state conversion and coil work great.
Ron
Old 08-08-2012, 04:25 PM
302 Z28's Avatar
I have some friends who have had problems with Pertronix units. I would spring for an HEI all in one unit or a Mallory.
Vince
Old 08-08-2012, 04:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
john
If it was me, I'd use a Duraspark. But if the amp box is a deal killer, sure... use an HEI.
But which/what ever you choose, be sure it includes a vacuum advance.
Isky Cam #396284/294-Finally Chose-Thoughts? Fastest65 Engine 0 08-12-2010 10:50 AM
The Experts Chose This Cam Canadian Charlie Engine 25 11-22-2005 05:51 PM
need help to chose a cam roy383ci Engine 16 03-25-2005 03:15 PM
How to chose nice torq convertor Bandit1980 Transmission - Rearend 13 01-03-2005 05:28 AM
Which Mustang Rack to Chose a54f100 Suspension - Brakes - Steering 0 04-03-2003 05:43 PM
