If you don't have an adjustable distributor and you are positive the drive shaft collar is all the way down on the pump shaft, you can get back 0.100” of that by using a Milodon p/n 32500 baffle under the oil pump. The rest can come from Mr. Gasket p/n 6059 shims. Or, all of it can come from the shims for that matter.
Cobalt 327, That sounds like a Plan and some good advice. I will drain it tomorrow and pull the pan. Tonight I will order the Shims, Spacer and New Pan Gasket. Since I do not have an adjustable distributor (MSD Low profile) I will shoot for just putting it back the way it ran last year. Distributor all the way down to the intake no gasket and the back it up with a .062 gasket. Thank You !! Dave |
Dave, just to let you know ahead of time, that baffle- should you use one- often requires clearancing so it doesn't rest directly on the rear cap bolts. If you are using studs, it for sure will need work.
Good luck. |
Cobalt 327,
I will note that when I get the Parts on Wednesday and start the install process. I will let you know if I find anything wrong with the pump and intermediate rod when I talk it a part tonight. Thanks Dave |
| Early Hemi: Carb flange mods on intake manifold? | tjet | Engine | 8 | 10-10-2010 10:32 PM |
| name that intake flange! | unstable | Engine | 18 | 05-13-2010 10:32 AM |
| holley domintor intake flange style? | chevelle4542speed | Engine | 1 | 11-08-2007 09:23 AM |
| coolant sitting on intake | montea | Engine | 9 | 02-12-2006 06:13 PM |
| 9" Housing Flange to Axle Flange | 68NovaSS | Transmission - Rearend | 2 | 10-14-2002 01:32 PM |
