Distributor gear material...at a loss? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 07:46 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Light at the end of the tunnel
I am running a SBC350 with a Comp Cams XE274 (hydraulic flat tappet) cam and an HEI distributor. I can't for the life of me figure out what dist gear material I need. It seems bronze is for roller cams...so that leaves: steel, iron, alum-bronze, or the ultra spendy composite gears.
Old 07-10-2012, 08:26 PM
Hot Rod Has Been
a stock steel gear is fine...
Old 07-10-2012, 08:32 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I think I'd just go with a stock replacement gear if it were mine.
NAPA Echlin #DG-501 fits a 1979 350
Attributes
# Distributor Drive Gear Teeth : 13
Distributor Gear & Pin I.D. : 0.490"
Distributor Gear & Pin O.D. : 1.50"
Distributor Gear Height : 1.80"
Distributor Gear Pitch Direction : Right Hand
Old 07-10-2012, 08:37 PM
Hot Rod Has Been
The best thing to do is throw away those catalogs... much cheaper that way.
Old 07-10-2012, 08:42 PM
66GMC's Avatar
I do the same thing with the sales flyers that come in the mailbox on a daily basis. Looking at them just plants the "I need that!" (or "I want that!") seed.
Old 07-11-2012, 08:17 AM
Advanced User
I did find some materials from Comp Cams that said I should use an iron gear on a flat tappet cam (which is made of iron). I have read that OEM's use a steel gear for street motors because steel lasts longer. This seems strange to me as I would think that a steel gear would eat up the teeth on the iron cam.
Old 07-11-2012, 09:03 AM
Hot Rod Has Been
I wasn't always that way... but I have changed.
#1 I pay cash for everything or use my debit card... no $$$ equals no buying.
#2 When building my blown Hemi my engine builder planted the idea in my head that these engines worked very well, won NASCAR races, with stock water pumps, oil pumps, etc. No one at Bonneville in the 50's went 200 MPH with a Chevy-cooled Hemi... so why would I need that stuff on my hot rod?
#3 My choice for buying hot rod parts are now salvage yards, other hot rodders and parts cars. And the occasional NAPA store and outfits like Egge machine.
Now back to our regular programming.
Old 07-11-2012, 09:04 AM
Hot Rod Has Been
I THINK some modern OHC engines use a billet cam... then steel would not be an issue. And the OEM's are looking for 200,000 mile durability I guess...
Old 07-11-2012, 11:32 AM
ericnova72's Avatar
More for Less Racer
OEM's now use steel gears because hydro ROLLER cams are steel.
For your Iron flat tappet cam, you want an Iron gear, for 1955-1985 SBC. The gear shown by 66GMC from NAPA is a correct piece.
Old 07-11-2012, 11:57 AM
Irelands child's Avatar
If it's a cast iron camshaft, the OEM style cast iron or even the later composite will work. If it's a steel core camshaft, steel or bronze. Word of warning with the bronze is that they will wear out in xxx to xxxx or maybe if lucky, xxxxx miles. The steel gears were introduced with the roller lifter camshafts and wear like ---- steel. You need to determine what that camshaft is made out of and Comp Cams have a forum you can ask or even give them a call and you will be have a lot better chance of them being right then a WAG* from us guys. If it's flat tappet, probably 90+% chance it's cast iron.
* WAG = Wild Azs Guess
350, chevy
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
Power Loss after Distributor Upgrade glennsea Engine 10 05-23-2010 09:00 PM
4l60e third gear loss mikethenut72 Transmission - Rearend 1 03-02-2008 05:21 PM
big power loss at 4 g's only in 3rd gear (700r4) help please mason71 Engine 6 03-27-2005 10:35 PM
Loss of gear Sampson Transmission - Rearend 1 07-20-2003 05:42 AM
