distributor gear problem
I have a 68 mustang I put a 351 windsor in, and it keeps wearing off the distributor gear. So far I have been through one cam gear and 3 distributor gears. I have changed distributors a couple of times, made a spacer to pick up the distributor out of the block a little, and tried a bronze gear that someone told me it would fix the problem. But obviousely that just wore down faster. I'm all out of ideas I need help please.
Have you spoken with a tech guy at the cam manufacturer about this?
no I don't have a high volume oil pump and I have not call the crane cams yet but this is the second cam from a diffrent manufacturer that it is doing it on.
Ok, there's alot of info that can be written here but I found some good stuff on the following links. http://www.fordracingparts.com/downl...tM-12390-A.pdf - and www.performancedistributors.com/technical.htm -
Basically it is recommended you use a new cam gear with a new dizzy gear as they may have a wear pattern to them. (not cheap), Increasing oil flow to this area is another option, (cheap), , and adjusting the dizzy height so it is not bottoming out and lines up correctly to the cam gear. Hope this helps, keep us posted |
Agree that the new cam gear and new distributor gear should be installed at the same time.... and then, check the distributor gear for wear pattern after maybe a few dozen miles to look for anything abnormal.
Some engines (notably the 460, not a known problem on the 351) had problems with the distributor pad height causing accelerated wear. |
I want to say thinks for the links I printed it all out and I'm going to give it try this weakend.
| I'm having a primer adhesion problem on one door | Ripped | Body - Exterior | 10 | 06-08-2007 12:45 PM |
| 96 Plymouth Voyager spark problem? | baddbob | Electrical | 12 | 05-19-2007 03:44 PM |
| 94 Dodge Transmission Electronics problem? | Native Gearhead | Transmission - Rearend | 7 | 10-17-2006 10:00 PM |
| Wiring problem is driving me crazy | pmeisel | Electrical | 7 | 07-12-2005 07:45 PM |
| Problem batch loading larger images | cboy | Hotrodders Site Suggestions and Help | 10 | 03-23-2005 08:26 PM |
