Distributor Gear use ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2007, 10:13 PM
driveability's Avatar
Last journal entry: 930 4 speed transmission
I got a New G.M. long block and it states I must use a "Distributor with melonized steel gear MUST be used".
I have this Distributor
Can anyone help me with this dilemma?
Old 03-09-2007, 10:42 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.sdparts.com/product/10456...butorGear.aspx
Old 03-10-2007, 07:24 AM
Buick Hybrid Guy.
Melons? :)
I've not run that type of gear. When I run a billet cam I normaly use a bronze gear or one of the other soft metal gears. From comp cam/Crane cam.
GM has some nice Melons.
I'll try that style with the next roller cam I use..
Cool!
Scott~
Old 03-10-2007, 11:35 AM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Make sure to check the size of the shaft in your distributor before ordering a gear. There are 2 different sizes of shafts used in Chevy distributors, .491 and .500. I believe only Accel uses the .491 size, but it never hurts to check.
Barry
Old 03-11-2007, 01:43 AM
http://www.sdparts.com/product/10456...butorGear.aspx is the GM melonized gear. I have no idea if it will fit a Mallory Distributor.
Old 03-11-2007, 12:33 PM
GM Tech
So has anyone tried the melonized gear? Is it more durable than a bronze gear? Sure is a lot cheaper than a plastic Comp Cams gear!
