Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor gear wear.
Old 07-13-2008, 06:25 PM
stroker_SS stroker_SS is offline
Everything is HAMMER!
This explains shims in between the gear drive and the housing, i was thinking shims inbetween the int. mani. and the dist.
I remember now that there was more damage on the dizzy, it appears as if the rotor is moving up and hitting the cap, there are plastic shavings embedded on the metal of the rotor. is this suspect?
