Distributor has a tube running along side of the distributor? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-17-2012, 09:10 PM
Two8tyThree's Avatar
Last journal entry: Picture of delivery
Each point has two screws. One screw locks the point down and the other is on a cam which moves the point. If I remember right the point gap is best at 0.016"
I have attached the tuneup manual as a pdf for the 56-7 Corvette below.
http://www.earlycorvettes.com/corvet...neUp56to57.pdf
PS - One added thought, if your dist housing is aluminum, then you have a Mallory aftermarket distributor. Prestolite is the mother company of Mallory.
http://www.mrgasket.com/
  #17 (permalink)
Old 01-17-2012, 11:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Seems like if you're going to use a non correct distributor, you'd want to use an electronic/HEI distributor w/a vacuum advance.
  #18 (permalink)
Old 01-18-2012, 07:25 PM
sscardino's Avatar
SF48
Two8yThree
You been a great help! Thank you. I have the manual saved. I like the pictures
Steve
Need help with sbc 350 running hot to one side TechTeach Engine 11 02-20-2011 01:16 PM
Distributor cap-side plug wire terminals cunningham Engine 6 08-19-2010 02:30 PM
BBC only running on one side of intake jake_arcticcat Engine 5 02-04-2009 11:38 AM
anyone running the MSD digital E curve pro billet distributor? dawg Engine 0 02-09-2008 01:58 PM
distributor moving from side to side pcoghlan Engine 16 05-31-2006 11:17 PM
