What do you meen by a "vacuum unit". If you are talking about a a vacuum activated choke pull off it will help with cold starts. Again pictures would be helpful
Artificial Intelligence is no match for Natural Stupidity Chet |
Vacuum...
Hello,
Thanks for taking the time. My Motors Manual referred to it as a Vacuum Unit, then the manual is 40 y/o. I attached a picture of the thing for you. What is the "oil cup". Does it have anything to do with the tube that runs up along side the distributor? I'm not sure if I should oil it/grease it/or leave it. Steve Last edited by sscardino; 01-15-2012 at 05:31 PM. Reason: Typ-O |
It should have a vacuum line on it, to the carb, or manifold... |
Like this
Nice pic, top bushing oil wick tube, fill'er up. No wonder we needed full service stations back when.
I believe that your distributor did not originally come in the 68 Vette.
I believe it to be a early model with only mechanical advance. Some of the early Vette distributors are worth a good bit of money.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
The pic I posted is a 55-56 Chev single point Delco (made by Prestolite) distributor (these dists were used in large trucks until 1961 according to GM). There was a later version 56-57 dist with dual points and a mech tach drive of similar design. The rest were Delco single or dual point dists with the advance weights above the points and below the rotor (some vette and trucks had mech tach drive also)
If I remember right very few 68 Vettes were 327s as the 350 was introduced in January 1969 with the early release of the 1969 Vette. The 1968 Vette 327s were large journal forged cranks, I believe and these are very rare as most 1968 327s and 307s were large journal cast cranks. So it is very possible that your Vette engine has been replaced with an earlier 327 especially if it has a sjc. Last edited by Two8tyThree; 01-17-2012 at 09:17 AM. |
Dual points/No vacuum advance visable
My distributor has no vacuum advance on it, at least not like the one that's shown in this pic. It also has dual points.. A different year distributor? Mmm, I wonder what year. Is it aftermarket or just a different year? I'm getting depressed here, I want to drive my car!! SS |
Take a pic of it and post it, there should be a Delco tag with a number on it riveted to the side.
By the way there is no vacuum advance on the one in the picture? Does it look like this: or this: Last edited by Two8tyThree; 01-17-2012 at 11:56 AM. |
Distributor
The first pic is it. Looks exactly like it. What year and modle did you say it came from (or did you ?
He may be looking at a tachometer cable for a mechanical tach a lot of vettes of that vintage had mech. tachs
Distributor numbers for the '68 Vette- http://corvetteactioncenter.com/specs/c3/1968/68id.html Tach drive cable/cable connection is at a 90 degree angle to distributor body, the oiler curves up to be more or less parallel to the body and has a cap on it.
That is a 1956-57 Corvette (Chev/GMC truck 1956-61) dual point Distributor.
I believe the your dist number should be one of these: 1100891 1100872 1100879 This dist takes: D-407 rotor D-305 cap D-103P points (2) dual D-203 condenser If you need parts or dist repairs, Bubba in Speedway, Indiana would be the guy to get them from. You can email him here: info@bubbashotrodshop.com http://www.lindertech.com/bhrs/index.html I hope this gets you going. |
| Need help with sbc 350 running hot to one side | TechTeach | Engine | 11 | 02-20-2011 01:16 PM |
| Distributor cap-side plug wire terminals | cunningham | Engine | 6 | 08-19-2010 02:30 PM |
| BBC only running on one side of intake | jake_arcticcat | Engine | 5 | 02-04-2009 11:38 AM |
| anyone running the MSD digital E curve pro billet distributor? | dawg | Engine | 0 | 02-09-2008 01:58 PM |
| distributor moving from side to side | pcoghlan | Engine | 16 | 05-31-2006 11:17 PM |
